Hello,
With Cobalt on a Cjr, I can't assign Local DMX1 and DMX2 to the same start address . It works with Congo V6.4.1. Is it impossible with Cobalt or is there a new procedure?
Jeanmi
Hello,
Jeanmi
This will be possible again with the upcoming v7.1.
I thought that you made an error when you write v7.1, but apparently no because, it don't work in the version 7.02.
Jeanmi
With Cobalt v7.1, It don't work (addressing made by the window " réglages DMX ").
Jeanmi
I agree with Jeanmi.
I tried doing this on my Congo Kid running 7.1.0 and I can't output on both ports as the same universe. If the second port overlaps with the universe assigned on port 1, it will not output anything on the second port unless the second port happens to be at or above the next universe break.
Hello,
Do you think you can solve the problem?
This function of mirroring output dmx is very useful for me.
Jeanmi
Hello -
This issue has been fixed in the v7.2 software, which will be entering beta testing very soon. Please keep an eye out for an invitation to participate in the beta testing in this forum.
Thanks -
Sarah
