Touchscreen to Congo Jr
Hi all
We are, finally, trying to buy some touchscreen to ours Congo Jrs with DVI splitter but I've got some questions about this.
- Is it possible to work with 1 touchscreen and a normal monitor at the same time on the same console??
- What is the best touchscreen to use with this console?? Is it only from ELO or can it be from another brand but with the same specifications??
Pedro Alves
  • Maybe this page from the wiki will help? http://community.etcconnect.com/wikis/products/eos-and-congo-family-monitor-configurations.aspx
  • Hello
    Touch screen need driver.
    the congo Jr has only the ELO driver inside.
    If you use another, Win XPe does not driver your touchscreen and ETC is very carefuly about risks if you install other items in your light board...
    On Congo hardware and Win XPe, you have use only 1 touch screen in the output 1 and not the mutlitouch.
    To have the best tool to work with the Cobalt software, a touchscreen to edit items in the sequence, for direct select and Device dock.
    Read ALL of the release note of the cobalt, some limitations about display and resolution are inside.
