Hi all -
We've found an issue when setting up shows with decimal channels on Cobalt Offline with a reduced channel count. If you set up a show using decimal channels on Offline, which defaults to 1024 channels, then open that show on a console or system running with a higher channel count, the decimal channels are not read properly and the system may crash.
If you are working with decimal channels in offline, we recommend increasing the channel count to the maximum value (5000 for Cobalt systems, 3072 if the show will be run on Congo hardware later) to avoid this problem.
We are working right now on a patch version and the fix for this has been included in that version, which should be released in the next couple of weeks.
Thanks much -
Sarah
