Touchosc
samson
Posted: Wednesday, July 30, 2014 7:51 AM
I would like to know if i can use touchosc to make a layer on a ipad and use it whith the cobalt nomad with midi showcontrol to control pan tilt and color. If it's possible can you explain to me
Thank you
Luke34178
Posted: Wednesday, July 30, 2014 8:50 AM
You can - but there is no need for MIDI - you can just use OSC.
Here is a TouchOSC layout that was made for Congo, it should work for Cobalt as well:
https://dl.dropboxusercontent.com/u/46189446/congo.touchosc
Hope that helps-
Luke
samson
Posted: Wednesday, July 30, 2014 11:35 AM
thanks a lot it s great for the pan tilt, i try to have fader for the color red green blue it's difficult to do?
Luke34178
Posted: Thursday, July 31, 2014 8:22 AM
Hue and Saturation are directly available via OSC. For Red/Green/Blue/Gobo/Frost/whatever, probably it is easiest to load a Master with that parameter and drive that Master via OSC.
samson
Posted: Thursday, July 31, 2014 1:40 PM
I try to load all this parametres on masters but i can't if you know how to do please tell me
thanks for all your help
samson
Posted: Saturday, August 2, 2014 9:52 AM
I found how to load parametres in a master with cobalt nomad you must have a touchscreen to load the paramametre in the master because you ha to press two buttom in the same time and it s impossible with the hold touch
Sarah Clausen
Posted: Monday, August 4, 2014 12:43 AM
Hi Samson -
You can "press and hold" any key in Nomad by using the CTRL key when you click, then click the next key in the shortcut. However, it's probably easier to make your edits in the Master List editor, rather than using console shortcuts. Go to the Browser>Masters>Master List, then find the master you want to adjust and use the Content Type (Parameter) and Content (whichever parameter name you want to assign) columns. Select the cell and press RETURN (MODIFY) to open the drop down menus in these cells. You can start typing the name of the thing you're looking for to speed scroll to that item in the drop down lists.
Hope that helps -
Sarah
