Hi all -
We've discovered an issue with regard to the use of decimal channels in chase effects and in channel sets. The decimal channels are not being stored properly in show files. We have not had any reports of this at all from the field, but noticed the problem in internal testing. If you were planning on using decimal channels in this way for upcoming shows, we recommend using a different kind of intensity effect (like content effects, dynamic effects, image effects or chase sequences) to produce your desired look. Another solution, if the number of effects or sets is small enough, would be to recreate the effect or set before the show starts.
Thanks much -
Sarah
