Hi, everybody!
I've just bought a XKeys XK60 and programmed it in ControllerMate using the standard PDF layout provided by ETC. The Cobalt software I have installed is V7.1.1.
However, there were some issues with the shortcuts provided in the documentation I thought I'd share with you all. (Cobalt_Hotkeys_PC_Mac_v7.0.0.pdf)
Select All is really Ctrl+N
Delay is really Ctrl+D
In is really Ctrl+I
Out is really Ctrl+O
- is really Ctrl+Keypad *
All is really Ctrl+F6 (also disabled conflicting shortcut in System Settings)
Go is really Ctrl+G
Release and Track - Disabled conflicting shortcuts in System Settings
Save is really Backspace (not Delete) + U (as is the shortcut on the console)
Insert is really Ctrl+Delete
Also, if anyone could tell me how to program the layer toggle without having to press twice, that would be much appreciated. :-)
Best regards,
Bjarne
EDIT:
Ulf Sandström made me aware of the help function of pressing [?] on the console, or F1 on the Mac, and a key states the correct shortcut. The hotkey document will hopefully be updated soon.
XK60 for Cobalt.cmate.zip
