Lock a group with a parameter (eg, focus, tilt)
Hello everyone.
I have learnt today that you can assign a specific attribute parameter to a Master.
Hey this is so Funky!!!!. But there comes also a problem with this.
Example:
Lets say that i control a LED Wash , parameter RED which is assigned to a Master 20.
When i select a differet channel  i loose the connection between the MASTER 20 and the LED Wash.
This is both great and sad for different situations.  Is there a funktion to lock a master with parameter to a specific group or channel?
Thanks / Fredrik
  • Assigning the attribute to a master is a universal parameter its not linked to the unit, the idea is that it can be used with any fixture that has a 'Red' Parameter.
    If you want it linked to only one fixture, you can do that. Put the LED Wash at full red (do not touch any other parameter or intensity) record that as a new preset Record Change Only and put it on a master. (It will ask you if you want to record attributes without intensity, just say yes)
    You will need to set your return FCB to previous and it should be what you are looking for.
  • Hey... thats great thank you!!!!
    i will try it tomorrow-
  • Another way to create this Preset is by using [MASK] to mask out any parameter(s) you don't want to record, then it doesn't matter which ones you've touched (eg you're in the middle of something else).
    [Mask] toggles masking on and off.
    [Mask] & [F], [C], [B], or [WHEEL_KEY] toggles whether parameters will get recorded.
    - You can even Record some Masks if you often want to filter out some types of parameter when doing other things.
    Finally, you can also open up the Preset Attribute Editor and [Delete] anything you don't want.
