Hello
we try to figure out to start a video on a Brightsign Mediaplayer with a simple UDP Command on Port 5000
The command ist just the number 1.
We have set the IP of the Console in the Settings.
And we set the IP where to send the Command and the Port under Showcontrol
But then what to do next?
We tried to put the command UDP 1 which is hopefully right in the Sequenz-List in the field "Macro-Aufruf", in English this is maybe Macro call or Macro execution.
But nothing happens, we tried to look with Wireshark whats comming but we see only multicast traffic.
Any help is appreciated. We can also use a COM Port but there is none on the backside of the Congo.
We have Connected the Networkcable on the Ethernet Port.
Thank you for any help
