Hi gang. Since the latest update, I have noticed the following issues
- Preset name not showing in master LCD, only the number.
- Preset definitely has text in the correct field.
- Whether preset is being used in any sequences or not, no name is displayed when assigned to a master.
- Recording selected fixtures directly to a master with [RECORD]+[MASTER] doesn’t use the next AVAILABLE preset number.
- Always uses preset 1.
- When using the new cues style for a stack, the last cue recorded sometimes appears in red and the cue name is not shown.
- Moving back through the stack the cue returns to normal on the display.
- As you move forward through the cues until that last recorded cue becomes the next cue it goes red again and the cue name disappears.
Has anybody else noticed this?
Cheers,
Drew.
