Hi All,
Is there any chance to add the extra channels with clone data in patch like as Eos?
Thank you,
Hi All,
Thank you,
In Patch select the channel you want to copy then press copy to then the destination channel and you will get 3 soft keys.
You will want to use Plus Show and then all the data will be added to the new channel.
So it should be X [Copy to] Y {Plus Show} [Enter].
Tom
