Is there a way that I can refresh the parameters in a sequence loaded to a master?
For example I have master 1 with a sequence on it, I go on step 1 turning the lights red. I fade out Master 1 start doing other things, making the lights blue etc.
Later I pull Master 1 up and want the lights to return to step 1's red, this is how a preset loaded to a master behaves. Instead the color is still blue, bringing the fader up from zero only recalls intensity from the step 1.
Is there any way for the Sequence masters to behave like the preset masters where you can use the attributes follow fader logic? If not is there any way to refresh the parameters so I don't have to [#][Master key] ?
