Hello!
Two things I would like to see fixed if possible:
1st Showing colours outside RGB/YCM mix. If you as an example have Amber leds on a RGBWA device cobalt display them as Black/non in Magic Sheet. Even white LEDs show up as black.
2nd is maybe a little harder but I would like that the rig don't Home/clear if I patch a device while having output. I often have very little time setting up and programming and are often adding things on the go. a special, a device that was in the wrong mode/address or so. and if I do that the whole rig goes out and Home. intensity on master stays but the rest goes black.Making it risky to add stuff live during rehearsals and so.
