Is it possible to fetch parameter times from a preset? If there is, I couldn't work it out. If not, is this possible to add to a future release.What I did was add parameter times with the wizard to sequentially fly-in some fixtures. I thought that if I had done that once, it would be nice to be able to fetch the times into another preset instead of having to rebuild the timing.What I experimented with as a work around for the main playback was to insert the preset which just had the mover position and timing with no intensity or other attributes into the sequence list and make that step a Move Fade step. In my first pass at it, that worked lovely.Take care,John
Hi John,
There is no way to fetch the parameter timing from a preset. It is a good idea though!
Anders
