I'm learning Cobalt using ETCnomad and am using presets to build my sequence. My question is how do you add a sequence step without creating a new preset? For example, I created a few presets which in turn created sequence steps but then I deleted all steps that referenced a certain preset. Now I want to add a step back in that references that same preset, how would I go about doing that?
Austen
Hi Austen,
If the sequence is on the Main Playback, [MODIFY] & [PLAYBACK] will open the sequence editor. Navigate to the step that you want the additional Preset to follow, #(of the additional preset) [INSERT].
Good luck,
John
Thanks John that worked great...
