Congo jr Replace Fixtures
Hi there,
I am running a tour and I am using Mac 2000 and Mac 600 NT from Martin. The next two shows are going to be on festivals where they are supplying Robe 1200 E AT Spot  instead of the Martin Mac 2000 and High End Studio Command Wash 1200 instead of the Martin Mac 600 NT. I have already programmed the show with the Martin fixtures  is there any way of Replacing them with the Robe an having the same show(Obviously not the Gobos and some other functions)?
Menelaos
  • Hi Menelaos -
    If you replace the template on a channel after you have programmed, parameters with the same names will retain their data. So, you may want to go into the Robe and High End templates and change (if needed) the parameter names for functions that are basically the same as in the Mac fixtures. Make sense?
    Then you will probably have to do some adjusting on site, but hopefully not too much.
    Thanks -
    Sarah
