Alpha keys not clearing from main display
Hi all, I am using a new Congo JR. console and have found a bug (I think).  When I go to the help screen (using the "?" key) and then press "text" to do a search, the main display shows the alpha keys so I can use that to type in characters (I usually just use the keyboard that is attached).  Once I have done the search and exit out of the help screen (using "ESC"), the main display keeps displaying the alpha keys!  In order to clear them I have to press some of the other keys around the display (like direct select) and then I will get the top half of the display back to normal but still show the bottom half with alpha keys (which stay until I hit an encoder wheel).  Has anyone else seen this?  It isn't a show stopper, but it is an annoyance.
