Hi all -
We have discovered a quirk in show files saved in version 6.3 - the "play has been changed" indicator that turns the show file name yellow on the screens is being saved into the show. This may be disconcerting for some users to see that yellow indication immediately on opening a show, or to not notice it until later and think that something may have changed.
To solve this, simply open the show, then save it twice. This will clear the indication.
If you do make changes and save the show, the indicator will once again be saved into the show. To avoid this, simply save the show twice.
We are sorry for this annoyance. We will fix this in the next release.
Thanks much -
Sarah
