Dynamics 6.3
Hi, l have just upgraded to 6.3 and I cant get the dynamic effects to work, I used to just select the fixtures I wanted open the dynamics and choose one and press load, now I go to an organiser tab when I press load but I cant find the dynamics in it!
  • Sorry, we didn't think anybody was still using that original function of Load, as the Dyn Effects are an older and less easy way of running effects than the Effect Playbacks.
    [Load] has been repurposed in 6.3 to open the new Organiser tab - this tab allows you to rearrange and copy show file data.
    You can still access the Congo v4 Dyn Effects using the [Dyn Effect] key (above [Effect]) - type the number of the dynamic and press Dyn Effect to apply it as you did before.
    I would also recommend that you take a look at the Effects Playbacks introduced in Congo v5 as they are much nicer to use than the legacy Dyn Effects in most situations.
    There are some quick tutorials here on the forum.
    [edited by: Richard at 8:44 AM (GMT -6) on Tue, Oct 9 2012]
  • Thanks! Guess I should really read the notes with each update.
