Template Bug ?
Hello
I am controlling the media server by using Congo.Jr. (Ver 4.3.3)
However, I am troubled by the template of catalyst now
If one line is input to range of the LTP8 parameter, one step of the wheel becomes changes five decimal.
One step of the wheel changes by one decimal if Range is not input.
Not only the display but also an actual output has changed into this by five decimals.
I want to change into one step of 255
For instance, this is important in the keystone of the media server.
The solution is not to input anything to the range editor.  Is there something a good idea?
[edited by: Usami at 11:08 PM (GMT -6) on Tue, Dec 25 2007]
  • you can make just 1 range from 0 to 255 and use finestep=1
  • Hi Pilou. Thank you for Reply
    Yes I Know But...
    It might be a role of Range table to change the display of each category by selecting the color parameter.
    For instance, the color parameter is made in Hue Sat and RGB parameter is made HSC when selecting it.
    Otherwise, there is no reason to use Range table.
    Range table is a wonderful function.
    The user can be made when this is used and an easy-to-use template be made.
    I want to make the template to which this is used, and the catalyst software is easy-to-use.
    As a result, the lighting console extends to the market of the image control.
    BTW
    A fine step is of application in the parameter in 16 bits.
    I do not think a fine step to become it effectively about one for LTP8.
  • This is bug generated only in  CongoJr.
    Dealer's person in charge taught.
    Thank you Shige
