Hi everybody
First of all sorry for this long text but I've got a question and some issues about Congo and maybe someone can help me.
The question is about MIDI.
How can I use MIDI to have a sound cue at the same time of a light cue? OK the details are this: I've got some cues on this play that as to be at the same time of Sound but sometimes on of us is a little bit late. So I think that we can solve this with MIDI but I don't know how to do that. Today we connect the consoles like this:
YAMAHA LS9 to MOTU ULTRALITE (Sound) to Congo Jr
I don't see any information on Congo Jr if MIDI is connect even after I went to SETUP to enable the MIDI Program Change and also the MSC. I read several times the online help of Congo but despite I almost understand the implementation chart I don't understand how the sound can do a GO on Congo Jr. So PLEASE can someone tell me how to connect this consoles?? What is the information that the sound console has to send to Congo Jr? How and where can see that information?
Now the issues:
- With a Congo as a server and a Congo Jr as backup, connected with a Hub the hourglass appears and blocks both consoles during some time. Not a long time, about 10 seconds, which is more than enough to miss a light cue. This happen sometimes but we can't say when or why because it's never on the same place of the play neither everyday. Just sometimes happens so we can't use this system because we don't want to put a show at risk but we need this.
- On Congo we've got a Macro that blocks also the console. This is a Macro just to dim the console lights for the show that opens the Browser, Console settings, put a number on those several boxes, Modify, and close the Browser. The problem is that sometimes it doesn't do everything and the window of the Console settings stays open. We can understand that is missing some steps of the Macro but we can't say exactly what steps. Every time this happen on the Display it appears the number 5655.
- If we try to do a crossfade with a Channel time using a Split mode a strange thing happen. Example:
Seq 9 Prs 6 OUT/IN 0.01 x(mode)
Seq 10 Prs 6.5 Wait 0.1 OUT 0.01 IN 1:30 s(mode)
Channel time 30
This Channel time is to put a channel at 50% before everything else but what happens is that channel goes to 50% on 30 seconds and after that, instead of remain at that intensity until the end of the crossfade, it goes down to some level and goes to 50% only after the remain minute of the crossfade. This is a very strange thing and we try with different channels and different times but this happens every time we use the Split mode. With the Crossfade mode the channel time works like it's supposed to work. So the question is why this happen? I thing that isn't a normal thing to do.
- We are using 5 ETC Revolutions on this show and when select all the 5 and send them to Home Attributes on the colors column we see a strange thing. 4 of them are with "1-White" but on the other one (the first one) doesn't appear anything. The color is on the right place but the color column it's different of the others. If we chose the Color palette 1 for the 5 Revolutions then appears on all "1-White". It's the first time that I saw this.
- We are using also 3 American DJ 1200 strobes and when we select all of the channels, 1Ch 1024 thru, we can't change the colors of the Revolutions. We send the colors to the last color that we've got on the scrollers but it only goes to the second color. We've got to deselect the Strobes so that we can see all the colors of the scrollers changing. Why this happen?? I think it's not normal cause Strobes doesn't have anything with Colors only with Beam.
Like I said before sorry for this long text and I'm hopeful that someone can help me about the MIDI.
Best regards
Pedro Alves
