Congo JR Crashes
Hello.
I want to report som issues with Congo JR version 6.3.1:
1: when you are in the help section and you use up and down arrow to jump between pages, the congo freezes after you have pressed arrowbutton 3-5 times.
2 It happened once that the congo locked itself when i tryed to exit channel only mode.
You are suposed to press the same button to exit channel only mode, but it dident worked.
After that i forced a reboot and after that it worked again.
/ Regards Fredrik Folkteatern Gothenbourg
