Hi folks,
Is there a way to shutdown master playbacks AND Main playback with a "solo" master flash or fader?
I know SOLO mode works with other master playbacks, but can't figure out if it can affect main playback as well...
thanks
Stephan
Hi folks,
thanks
Stephan
No, the Main Playback is not affected by Solo on Masters.
If you want a solo Flash to take down your main sequence, you can put the Sequence on a Master and use the Master Playback instead of the Main Playback - perhaps with Dual Fader Mode and/or "Connect"ed to the big Master [>] buttons.
