Attribute playback option
Can I suggest a new Sequence attribute playback option that would be that devices not active in a preset would seek out and go to their next attribute values as suppose to waiting until the information for change is in the B playback. I have issues with a show using alot of wait times.
The work around is to record the changes earlier with the channels at Mark (I use Active recording mode) but this takes time as well as needing updating when changing the attributes in the preset last in line.
Thanks, Orri
