Hi all,
Just wondering if I can convert zero 88 fies to congo in some sort of way. Its a play show so I dont need chases or macros ect.....
Thanking you in advance
Carl
Hi all,
Carl
Hi Carl,
In what format is the Zero88 showfile? Is it in ASCII? Can you open the showfile in Notepad or Wordpad and read what's in the show. If the file is in ASCII then you should be able to just open it in Congo. You might need to change the file type to .asc. Normally at least patch, sequences, presets/cues and times are imported from ASCII shows. To see what an ASCII show looks like, try opening a Congo show in Notepad or Wordpad.
A qucik look at the Zero88 site did not give me much info about the format of their showfiles, but it seems it's not ASCII. If the Zero88 show is not in ASCII format or if Zero88 does not have any sort of conversion tool/software to convert to ASCII, then you're pretty much out of luck. Sorry.
A few related topics on the Zero88 forum:
http://support.zero88.com/forum/index.php?showtopic=3347
http://support.zero88.com/forum/index.php?showtopic=104&hl=ascii
http://support.zero88.com/forum/index.php?showtopic=70&hl=ascii&st=0
