Channel Layout
I have drawn a channel layout for my F.O.H and would like to keep in all my new show files how do i do this
thanks
zach
  • The easiest way is to set up a default show file. You set the desk up the way you want it ( at mode or direct mode, screens, your standard groups and so on) save it as default show and then start programming with this file every time you start programming.
    Or you go in Browser->Files->Import, then choose the file that includes you channel layout and import it into your show file
    Hope that helps
    Florian
