You'll need to do an ASCII export from Ion and then import than on Congo. Be aware that some things won't carry across quite right though due to the conceptual differences in some areas. Most of your level and cue data is fine though.
Dan
You have to export the eos showfile as an usitt ascii file .asc. Then you should be able to open in congo. You might want to update you congo to the latest release v6.4.1
Thanks for the replys guys.. got sorted by downloading offline editor and converting over!
Thanks again for help..
