hello!
i'd like to reset the timecode during the show. is it possible with a keyboard-shortcut or a macro? or is it only posible with the mouse in the timecode-dock on the main screen?(ver v6.3.2)
thanx in advance...martin.
hello!
If I'm using timecode during a sequence Martin i use a recorded macro ( # & Learn macro) . Click the reset timecode button then click on the red 'recording macro ' - top right of the monitor screen.
When you need a reset of the timecode in a sequence step , you can insert the above macro number ( #) in the seq its needed.
Anytime you want to do it manually - use # then [MACRO] softkey
