Template for Chromlech-Jarag 5
Hello.
Anyone out there having template for Chromlech Jarag-5 ?????
Regards
Anders
anders.nilsson@svt.se
  • See attached showfile for templates!
    There are two templates - "Jarag5 5 chan" for fixture version 1.2 and "Jarag5 6 chan" for v2.0
    I've treated the 'effects' it does as Gobos as that seems to make the most sense:
    • "Gobo" to select Sequences
    • "Gobo Mode" to select Sequence Banks
    • "Gobo <>" to set the Sequence Step/Rate
    • "Gobo rot" to mirror and rotate the image for the 6-channel mode.
    • "Beam Speed" to set Fade rate
    In 25-channel mode, it should be patched as 25 dimmers.
    In 31-channel mode, is should be patched as a "Jarag5 6 chan" followed by 25 dimmers.
    [edited by: Richard at 7:15 AM (GMT -6) on Wed, Mar 12 2008] [edited by: Richard at 7:15 AM (GMT -6) on Wed, Mar 12 2008]
    jarag5.asc
