we have a congo kid running cobalt soft.. Is it possible to use a touchscreen for easier use?
Hi Filip -
Yes you can. The real question is what kind of touchscreen can you use - if your console has any VGA connectors on the back you will need to use a classic touchscreen (meaning no multi touch monitors will work). If the console has any display port (looks a bit like an HDMI connector) on the back, you can use Windows 7 compatible monitors (meaning multi touch).
You can find out more about touch screen monitors here: http://www.etcconnect.com/Support/Articles/Touchscreen-Monitors.aspx
Thanks much
