HI,
I have just installed V5 on the congo. on the old versions dynamic effects used to be on the direct selects can you do this on v5 as this speeds up time on plotting and in live shows.
Can you do it
please reply ASAP
thanks
Zach
HI,
Can you do it
please reply ASAP
thanks
Zach
We have taken away the Direct Select type called Dynamics that was used with the old type of Dynamics to make space for other direct select content.
However, if you use the new Dynamic effect in the new effects package, you will be able to show the dynamic libraries on the Direct Select, since they are just like ranges on any device. Just hold down the corresponding parameter button and the direct selects will populate with the different ranges.
