I've found a couple of bugs in v5.
If you split the views left/right (Tab + Down Arrow) the zoom on the live screen doesn't stay correct. The channels go to half the size. This doesn't happen if you split top/bottom. I was in the non-zero format and didn't check any others.
When you open the Channel List to patch the dimmer column is much wider than it needs to be. This pushes the other columns off the screen and makes navigating difficult until you resize the dimmer column. This may only happen once each time you power up but I'm not sure about that.
The client isn't working. The console will show the client as a Net2 device but the laptop hangs at the startup screen. (This is being addressed through other channels.)
Not bad so far and I'm a big fan of a lot of the new features.
