Dragging a box round channels in live tab - not possible?
A great feature that the congo is missing, is that you cant drag a box (using the mouse) around channels to select channels, in either the live or blind tabs. However ive found you can do this in the channel layouts page when you are drawing a rig. Again this would be a great help if you could drag a box round channels. Its a bit fustrating to have to click each one. Groups are great but ive found im getting too many groups stored up and im losing myself in trying to remember numbers.
 Again i might have missed somthing like a box in the settings to do this, but ive looked every where and cant find anything.
Chris!
  • Hi Chirs,
    It's true that you cannot drag a box to select channels in the Live tab. But, Congo has been designed so you would not have to use the mouse. That's probably why draging a box to select channels isn't implemented. However, your wish is noted.
    Trying to resolve your issue another way. You could record Groups and add the Groups to a channel layout. Just select to insert Groups, instead of channels (or use the Wizard). You'll then see the Groups and their texts on the layout an can click on them with the mouse to select the channels in the group. Would this work for you?
    Oskar
