Hi everyone,
I would like to do a personality for Clay Paky Alpha 300 Beam (Standard mode) to make a use of two control channels available in this fixture. One channel is for reset functions, second is for lamp control.
Here is a link to DMX Charts:
http://www.claypaky.it/support/pdf/Alpha%20Beam%20300_Channels.pdf
or more documents like Manual:
http://www.claypaky.it/english/support.htm
Is it possible form the Device > Control > … to have control of two DMX channel values that device has?
Now inserting CP alpha 300 from Congo’s extended library, in “Device > Control” there are options:
- Lamp Idle
- Lamp On
- Lamp Off
- Lamp Reset
Only “Lamp Reset” works from these four and should be labeled as "Fixture Reset" because it does fixture reset (not the lamp reset). So how to do a CleanUp with this? How to make only necessary options with proper labels and bring them to life - for me it will be:
- Lamp On
- Lamp Off
- Fixture Reset
Please write how to do it on the Clay Paky Alpha 300 Beam example.
Many thanks ;-)
Adam
