We updated our Congo jr from v4.33 too v5 some days ago. Earlier dynamics could be found on the direct select part, but after we updated we can't find it.
We would like the Dynamics too be found on the direct select, how ??
This function was removed from the Direct Selects in version 5, to give space for the Gel picker function.
However, because v5 Effects are merely a special kind of channel, you can use the Param Direct Select option to put whichever table you want there.
To do this:
Now you can select any Dynamic Effect Playback and choose which effect it should be running using Direct Selects.
You can also do this with the other attributes of an Effect Playback, such as which Group/Set it is applying the effect to!
