Today I tried updating a full-size Congo console from 4.2.0 to 4.2.1, using a "Memorex Traveldrive" USB memory stick, and had no luck following the normal update procedure because the "Software Update" button was greyed out.
When I connect the Memorex Traveldrive to my computer, and then open My Computer, I see two new drives appear - the first is Drive E: which is labelled "U3 System Files" and contains an .exe and autorun.inf files (which obviously causes all the friggen' popups to appear when I connect the thing!! aargh!), and a second drive which is Drive I: (my next available drive ID - in Congo it was F:), which I can actually store files to normally. As a factory-scum hoax user, I put the SOFTWARE folder and congo.exe on this second drive, and Congo did not seem to see the file. Is this because it was on a drive other than E:?
Anyone seen similar problems before?
FWIW I upgraded the console by pointing to the congo.exe file directly in the Advanced Settings window.
Thanks.
Alex Mair
Jands Pty Ltd
[edited by: Alex Mair at 9:44 PM (GMT -6) on Tue, Mar 13 2007] [edited by: Alex Mair at 9:43 PM (GMT -6) on Tue, Mar 13 2007] [edited by: Alex Mair at 9:42 PM (GMT -6) on Tue, Mar 13 2007]
