Dynaminc Effect start?
Is there anyone ho knows if it is possible to get a dynamic effect to fade in when you start it from the master panel? And i don't  wish to make a preset!
it would be nice if the dynamic effect fade in(size and speed) when you pull up the master that the effect is place on!
  • Having a dynamic effect as content on a master will just activate the corresponding effect for the selected channels. It works like a macro command to give you a possibility to quickly activate different effect types for the current selection.
    This means that you cannot program it to contain a specfic effect, a set of channels and other parameters.
    The only way to record an effect like you want is to record it to a preset (and possibly put the preset in a sequence). Then the master will scale the size of the effect.
  • I use dynamic effects on masters as presets live all the time. As long as you don't record any of the fixture attributes into the preset other than the effect it works fine.
