Screen Resolution...Update!
When I purchased the Congo, I also purchased 15" LCD screens. But I always found that the resolution (1024X768) wasn't enough for my large number of fixtures in my channel layouts. So when I got the Jr, I purchased 17" LCD's, and the resolution (1024X768) want's great either. So I went in System Setting, Advance Settings. And changed the resolution to a higher one...and what a difference it makes! I can see more info w/o a third monitor!
So if anyone is using 17" displays, I would suggest changing the resolution. But is this Ok?
The only issue I see is docking (Masters, Moving Lts, etc...) Can you resize them? I only get half of them now (i.e. ML gets cut off in half when docked below)
MZ
  • You can easily change the size of the docking areas, using the same command as you would use to resize the Browser (which in fact is a docking area as well).
    Focus the docking area you want to resize (by clicking on its header bar or by using the BROWSER & arrow keys shortcut).
    Hold BROWSER and change the size with the level wheel.
