Congo Net3 RFR Questions...
1)  Can an Output (Dimmer for old school users like me) check be accomplished using the RFR?  It appears that it can be done if the console is already in Output Editor mode by using the "+" and "-" key - but no go otherwise.  If so, how?
2)  Is there a way to do a range patch (ie output 1-10 into channel 20) using the RFR?  If so, how?
3)  Anyone else experience an issue of having a handful of presets (with labels), say presets 1-15 (give or take another handful), scroll through the presets then scroll back and have say preset 1 cut off the top portion of the screen?
4)  Can only presets be recorded via the RFR?  I guess what I am asking is there a way to record groups using the RFR?  If so, how?
[edited by: Dana at 8:42 AM (GMT -6) on Fri, Jun 27 2008]
  • Hi Dana -
    1) Not yet, I believe.
    2) I don't believe so.
    3) We haven't seen this, but will take a look.
    4) Probably not directly.
    Good questions! I'll look at adding these functions to the spec for the next RFR release.
    Thanks -
    Sarah
  • Thank you for the quick response.  I appreciate your time taking a look at these questions.  In all honesty it may just be myself trying to use a remote as a full console.
    -Dana
