V5 Chase effect
Dumb question I'm sure but here goes,
Having created a chase effect, is it possible to assign it to a master? I'm sorry if this has already been covered in a previous question, I have looked and also read Sarah's instructions but to no avail.
 Regards
John
  • Hi John,
    Select your Effects ouput and put it at a level. ( # EFFECT @level )
    Then to load it to a master, press and hold CH/ID and then press the master select for the master that you want to load it into.
    Now this will just put the Effect Playback in the master.  It will not necessarily have the chase you want in the Effect Playback because the chase is an attribute of the Effect Playback.  To make sure that the Effect Playback has the correct chase, you can just put the Effect at a level and record it as a Preset directly to a Master.
    I load my effects with palettes before I start my shows and put the effects in the master, so I can use the master select key to select an effect and have the U1/U3 keys available with minimal button pushes and maximum flexibility on the fly. YMMV.
    Take care,
    John
  • Thanks John,
    Will try that.
    Regards
    John
