Can't FETCH/ON or ALIGN devices. CONGO JR.
I'm programming on CONGO Jr, and haven't been able to Fetch/On attributes from other presets (no problem with intensities). I have read through this section of the manual and tried it exactly as described, plus a few other ways that seemed intuitive, but no luck.
Any Ideas?
I am programming 3 Mac 700's, that otherwise appear to be okay.
We can record palletes, but this is a very roundabout way to grab attributes out of other presets.
- Jen
  • Hi Jen -
    You can only fetch parameter data out of the presets that contain the actual moves. If you are using the Attribute recording method of "Automatic" then only changed parameters get recorded. Could you verify that the presets you are trying to fetch from actually contain the data you are trying to fetch? If they do, can you tell me the syntax you are using?
    If this doesn't help, please let me know.
    Thanks -
    Sarah
