Something new i found under download/congo.
Pär
Pär
These are the drivers required for the new ETC Touchscreen for Congo/Eos family.
If you buy your Congo now, the drivers are already installed, but if you already have a Congo and
then buy the ETC Touchscreen, then you need to install these drivers, so that the touch-function
of the Touchscreen work.
Hope that helps!
I use ELO touchscreens 19". I´m not quite happy with the elo driver. I have to recalibrate often and position is not accurat over the screen.
Can I use the new etc driver and will that be an improvment?
Pär
Your ELO Touchscreen is supported by the Congo.
Try Downloading the ELO Installatin Files from our website here,
http://www.etcconnect.com/product.downloads.aspx?ID=20015
and install and reconfigure the touch and see if that helps.
If not - please contact the Tech Services nearest you.
What country are you in?
- corey
