This unit only takes one DMX address, so you can patch it as a dimmer to a channel and use the intensity of that channel to control the snow machine as described in its user manual. You can use the Patch Wizard's "Patch Dimmers" tab to patch this one value, or you can patch it in the Output Editor, Channel List or Output List.
Thanks -
Sarah
