Hey Guys
Im working on programing a show on our Congo Jr. and can not figure out how to create an auto follow cue.
I can do it on an express with my eyes closed but haven't figured it out on the congo.
Anyone know how?
~Alex
Hey Guys
Anyone know how?
~Alex
Just open your sequence list and put however long of a wait you need into the the wait field for the que you'd like to autofollow. As it's an ETC product, the wait time is activated after the previous que has completed.
HTH
Jason
There is also a 'Wait' softkey available in the Main Display at the top of the console.
Put it into softkey mode, then hit the "<-- " button a few times to get to the top of the menu, then "Times" softkey.
You can now type a number and press 'Wait' to put this time into the sequence step currently in the A or B fader (depending on your 'Set Times To' setting)
The operation of the Wait times can also be changed from the ETC default of "After fade completes" to "When fade starts" by changing the "WFA" setting in the Sequence List to "F" for Follow-on in the step required.
(In 4.2.1 this was a global setting, it can now be changed for each sequence step as required)
Richard:
The operation of the Wait times can also be changed from the ETC default of "After fade completes" to "When fade starts" by changing the "WFA" setting in the Sequence List to "F" for Follow-on in the step required.(In 4.2.1 this was a global setting, it can now be changed for each sequence step as required)
Oo! Nice feature tweak!!Anne
