Small Question?
Hi All,
I have some questions of Congo/jr?
- How to delete a range of Presets, Groups, Squences etc... at a time ?
- What is function of [Effect] Key?
- When I put the Chase into Main play and play the chase. How to stop the running of chase?
[edited by: KK Yeung at 3:18 PM (GMT -6) on Thu, May 03 2007]
  • Hi KK -
    You cannot delete ranges of presets or any other data at this time. They have to be deleted one by one. In some cases, it may be easier to import the patch and other parts into a new play rather than delete all of the objects you want to remove. It just depends on what you are trying to do.
    The Effect key is reserved for future use. Stay tuned for some really cool functions related to that key in the next major software release...
    I believe you can use the PAUSE key to stop the chase running. In most cases, chases are not run on the main playback. Chases can be assigned to Masters and fired by a step on the main playback using a Master Link.
    I hope this helps -
    Sarah
  •  Thanks, Sarah.
