Midi Show Control Problem
I think I've found a problem with MSC on our Congo Jnr. If we have a fade running and send a go message for the next cue, the next cue will snap up regardless of the fade times for it. If I press go on the front panel the fade will happen as expected. This only happens if the GO command is sent before the end of the previous fade.
Richard
  • Hi Richard,
     I don't have answers for you. May I have question about the MSC. I tried to connect two congo with Midi cable & check the MSC box. two consoles' ID set to "1". It doesn't work (check that the Midi cable is OK).
    Have any stuff I need to do?
    Can the MSC use with one Congo console and one Express console?
  • KK Yeung, I'm not sure that what you're trying to do is possible, I don't think the desk sends MIDI Show Control just responds to it.
    After some investigation of the problem I'm having, I have a slight correction to the problem.
    Say we have two cues,1 & 2 with fade times of 10s each. A GO command to cue one is sent and the cue starts fading normally. At, say, 7 seconds into the fade a GO command for cue 2 is sent the desk will jump to the state of 7 seconds into the fade to cue 2 and then continue the fade normally.
    I'm assuming this is incorrect, as I'd expect it to behave like pressing the GO buttom on the main playback, i.e. cue 1 would stop faing and cue 2 would fade in over 10s.
  • richard_cooper:
    Hi Richard,
    If you want to change this behavior, you need to change the cue1 to lookfade in the sequence list. This looks all channels which are changing in cue 1  and they are not affected by the following cue. I use this all the time for dusk till dawn fades on my cyc.
    Florian
  • Hi Florian,
    I'm not sure I'm managing to explain this properly, it's not a cross fade/lock fade thing.
     A bit more investigation reveals that a MSC "Go Cue x" command is similar to a "x GOTO" on the desk. You can see the issue I'm having without using midi. Record two presets in a sequence say 1, channel 1@100% fade time 20s, cue 2 channel 1@0% Channel 2@100%.
    Type "1 GOTO" will start the fade, at about 10s channel one will be at about 50%, type "2 GOTO"  channel 1 will snap to zero, channel 2 snaps to 50% and then continues fading up in the remaining 50% of the time.
     I'm sure this can't be correct, well maybe it's correct behavior for the intended use of the GOTO button, but not not of a midi show control GO message. If I do the same on our other desk (520i) via MSC I will get Ch1 getting to 50% in about 10s then when the second go command is sent Ch1 will fade down to 0, from the 50% it had reached, over 20s, whilst Ch2 will fade up in 20s.
    Richard
    [edited by: richard_cooper at 9:44 AM (GMT -6) on Sun, May 13 2007] Edited to make slightly more sense!
  • I understand your problem now. You are correct in that Go Cue x actually makes a # GOTO on the Congo. This is how it is currently implemented.
    We should probably consider changing the behavior of the Go Cue x to allow for a Go Ahead (starting the next fade on top of the existing one in a smooth way). Currently, this isn't possible.
  • Anders,
    Thanks for the reply. I definitely think the behavior of the Go Cue x command needs looking at, as in its current form it makes MSC rather unpredictable in a live setting.
    Just out of interest, I'm trying to work out the rational behind how the x GOTO command behaves in this instance? It seems to be of no benefit for GOTO to behave in this manner.
    Richard
  • I agree that we should consider changing the basic behaviour of GOTO (which would "fix" the Go Cue x problem as well). I cannot see the rational behind it skipping ongoing cues.
  • Regarding sending MSC Cue information: This is currently not supported by Congo. Congo only reponds to MSC Cue messages.
