Hi there,
If you know the range of your fixture then I would delete the ranges that congo have made for you and input your own, Ive done this with a few of my fixtures just makes it easier as you know what you want in the Direct select keys.
As makeing 2 parameters I dont know why you need to as you can only use 1 at a time if they are on the same DMX address Int or strobe.
This is only my 2 pence worth, if it works for you then leave it your way.
Carlos
OOOOooo OK I had this problem with my pixelines, all I did was to change my Int to Beam in the Parameter editor,The only problem this gave me was when I wanted to change the Int time it changed the Beam times as well, I then had to do this with indervidual times in the editor.
This gives you the Int on beam button then you can set ranges this way !!!!!!!!!!!!!!
Hope this makes sence.
Carlos
