3rd screen on jr.?
hi everybody,
is it possible to work with a 3rd screen on congo jr?
there is a vga port on the jr but it its not working. only the two ports at the Adapter (DVI -> 2x dvi/vga) are working.
maybe i can connect a touchscreen to the vga.
thanks for help
greets
Sebastian
  • Hi Sebastian,
    CongoJr can only support two monitors. The VGA port on the back is disabled and cannot be used with Congo.
    Touchscreens with special drivers are not supported in Congo. But if you have a touchscreen that is recognised by a computer as a standard mouse, it will work with Congo.
    Hope it helps,
    Oskar
