channel select in Layout view?
is it possible to select a device in Device-LAyout view for editing? I build my venue and it would be great if i can select my devices here...
any idea??
Sebastian
  • If you set out your layout correct with the same channel numbers then yes just use the mouse to select the units or use the keypad as you would usually,
    But remeber you can only access this from the Live Tab, Press format in live until you see you channel layout screen.
    Hope this Helps
    Carlos
