To the next with level
Is it possible in one of the next versions to get a function that make it possible to jump to the next channel WITH LEVEL  with the + button - or does this already exists and I´m too stupid to find it??
Sabine
  • Unfortunately, there is no such function. It is currently not planned to be implemented either. But we'll add it to the wish list for future versions.
  • If you mean in a channel check type mode, holding C/Alt and + will step to the next channel at the current level.  You must keep holding C/Alt to stay in the channel check mode.  If you release C/Alt the channel will stay up but you will have to reenter the channel & level information to get back into channel check mode.
    Take care,
    John
  • Press ALL then use NEXT and LAST. If you want to include levels from masters, press ALL ALL instead. :-) (Thanks Florian!)
    Thanks -
    Sarah
