Hi all,
Apologies for asking something that I'm sure has been asked before, but here goes...
What is the easiest/cheapish way to connect 2 Juniors together in a main & backup config?
Regards
John
Hi all,
Regards
John
To set two Congo jrs together as Server/Backup, you'll need a standard 100MB capable Network Switch and a pair of Cat5 or better straight-through cables.
If you already have a lighting network, the two simply plug into this network via Cat5 patch cables.
Before plugging in, there are a couple of settings you need to check in "System Settings" from the Welcome screen:
Once these are set, plug both consoles into the network and turn them on.
Now, take both consoles to "System Settings", and do the following on both consoles:
Finally, start the Server console.
Once it has loaded, the Backup will show "Backup" as an option. Start this console as Backup.
Once the Backup completes loading, it will receive a copy of the showfile from the Server and should get a pale Blue background behind the tabs, and say "Backup Sync" at the top.
The Server will also say "Backup Sync" at the top of the monitors, and you'll probably see "Play sent to backup" in the message box at the bottom.
At this point, the two consoles are in Synchronised Backup mode - as you progress though the play, the Backup will match the playback of the Server.
However, 'live edits' using the keypad, Records and Updates are not automatically transferred to the Backup. This is to make it much less likely that an action that causes issues on the Server can affect the Backup.
At any point, you can use Browser > General > Network > Server > Send Play to resend the updates to the backup.
You can set it to automatically re-sync whenever a Preset is updated by ticking the "Auto-Send play on Record" option in Settings > System.
The console will always automatically re-sync whenever you save or load the play.
Finally, to get the data out to your lighting rig you have a couple of choices:
Hi John,
it's funny you know.only today did i ask someone the very same question.
thanks for doing the post,look forward to some answers.
ges.
Hi Richard,
thanks for the info,that is exactly what i needed.
have a nice weekend
ges.
Thanks Richard
